I can lower (deploy) the backhoe, but none of the controls at the backhoe do anything. Is there an over ride switch that would prevent anything to work?
I can switch the RPM control to 2000RPM but nothing happens, neither on the driver side by the frame, nor the hi/low switch at the backhoe part will do anything. Does that switch have to work for the backhoe to do anything?
You guys expert advice is highly appreciated
