cobia2017
- 34
- 18
- chesterfield, va
Hey guys, appreciate any help you guys can offer....issue: wait light on for a much longer time than usual occurred gradually but i can still hear the relay click but it takes like 30 seconds at least and motor will not start cold. (without starter fluid) I checked all glow plugs and about half were not working, so i replace them all so that now all glow plugs are working but still same exact problem, so I started testing the harness - test light at the green wire feeding the individual plugs gets no light, test light at the the glow plug relay where the input wire from the ignition switch attaches does light up, next I was testing the bigger two orange wires from the copper studs exiting from the relay when I noticed some smoking from the resistors and of course turned off ignition. and stopped the process it was getting dark anyway....Thoughts? resistors bad all of a sudden now that the plugs are all new and making the circuit complete? plugs are 60G ac delco. I wouldn't think its the fuseable link prior to the resistor from the buss bar?...I have reviewed threads on here and the wiring diagram but am stuck, any help really appreciated, Thanks Robbie
