M548a1
h1x2
77
Illinois
I bought an M548a1. It’s being delivered next week. I’ve never been around one and I’m not familiar with how they drive. I have to unload it off the trailer when it arrives. Is anyone familiar with these that could give me some quick instructions? I haven’t been able to find a manual or anything. I’m not even sure I’m posting this in the correct forum.
Thank you
19,766
Thank you
Just have the driver drop it off and my place...
I would be happy to drive it off the trailer :cool:
In all honesty, the visuals out of the front isn't half bad. If you are backing it off the trailer you will be completely dependent on your hauler. Chances are he or she will be as concerned as you are about getting that tracked vehicle on the ground safely. Strongly suggest that you and they confirm hand signals. You know... A little pinch motion means a tiny movement, and the driver should be able to see the loadmaster (driver). Motion to the left should mean the vehicle needs to go left and so on. SMALL movements all the time!
If the unload doesn't seem to be working smoothly, shut it down. Then get out and talk it over, reset and start over. It is hard to depend on somebody that you don't really know that well - but it has to be for a safe unload.
19,766
19,766
When I got my M5 Stuart I was in the same boat. I had to read the manual while it was on the trailer to figure out how to get drive it off
My first was the old M4 Tractor. Lots of loads.
Hangs off both sides of a standard lowboy and metal tracks on metal trailer is a lot like pulling a greased string out of a billygoat's butt.
Bill Nutting
1,284
Chesterfield, Mi.
Thank you
Welcome to the site from Michigan. Go to post number three and click the link that SETOYOTA gave you. That is the link to the manual you should review before your vehicle arrives.
fuzzytoaster
3,132
Fort Worth, Texas
They're much like older dozers with the two levers. Take your time with it and watch your spotter. Don't over think it and be aware of your surroundings. Here's a video of one I bid on a few months ago.
WillWagner
2,758
Monrovia, Ca.
Main controls, throttle pedal, gear selector, ign on, start button, engine stop cable and two brake control sticks. It has a 4 speed auto in it, IIRC, make sure the brakes are set. The sticks should be pulled all the way back and locked with the buttons on the top of the handles. Make sure the trans is in neutral, engine stop cable pulled. Power on, and crank. After a few revolutions, push the stop cable in and hit the start button. If it is a good runner, it will fire immediately. Look at your oil pressure, if it is good, select reverse, watch your guide and release the brake by pulling back on both sticks and pushing the buttons and SLOWLY let the sticks move forward. REMEMBER, these are your brakes, the sticks can be hard to pull on to get good braking. Pulling back on the left brakes the left track, the front will pull left in fwd and rear pulls opposite in reverse, same for the right. Remember when backing, brake with the opposite stick that you need to move the track to, if the track needs to move to the right, pull on the left stick.
To kill it, stop the carrier, set the brakes, put in N, ign off and pull the shut off cable out.
Is it on a gooseneck or Landoll type of trailer?
Guyfang
24,079
Burgkunstadt, Germany
I am going to toss in my two cents now. Driving a M548 is like driving a boat, if you have never driven a tracked vehicle with Pivot steering.
You can not go slow enough!
Will Wagner broke it down right. Its not hard, but you got to pay attention. My drivers training on the Beast, (it was a modified 548 chassis, turned into a XM727 HAWK Launcher) was about as long as Will's write up, then I drove it off a Missile site and onto the German road system. So its not hard. I will admit that I killed 40-50 road side markers, slammend my toed radar trailer against the Autobahn guard rail once, and scared the other three guys in the cab with me to death.
What I am getting at is if the engine runs well and the governor has been removed or disconnected, that baby can move. When you want to slow or stop, evenly apply pressure to the laterals, (sticks). Too much in one direction can lead to you needing to repair something you have bumped or ran over. Never back up without a ground guide, and we never drove it forward without a ground guide unless we were on a road, and moving at speed. Take it to a VERY large field to learn how to drive it. Its more fun then drugs!! Good luck.
h1x2
77
Illinois
Thank you. Exactly what I was looking for. Appreciate the step by step
h1x2
77
Illinois
It’s coming on a step deck with ramps. Some of the machines I’ve seen have smaller rubber pads on the tracks. The one I purchased seems to have rubber Over the whole track. Should give it some more traction coming off the trailer.
19,766
In a perfect world - assuming that it is straight on the trailer - you might be able to leave the steering clutches alone - and drive slowly down the ramps. The "tip over" where the vehicle goes from flat on the trailer to hanging over the ramps... Just before it breaks over onto the ramps is the "spooky" part. As has been said before MOVE SLOWLY. Really slow and with eyes outside on the ground watching and giving directions.
WillWagner
2,758
Monrovia, Ca.
Good, not meaning to scare ya, but that is WAY better than a tilt Landoll! It can be scary backin, well moving fwd too, on a tilt bed, I hate that! Just had to do that with a 54k aircraft tug! Yes the "tip over" can be a pucker factor!
Take pic of the tracks.....
Guyfang
24,079
You also do less damage to what ever driving surface you are on.
