Grounding Mep-802a while load testing etc
ribs1
21
Michigan
Hello,
I have the Map-802a properly grounded when connected to my house through a transfer switch.
My question is when I am not connected to the house for load testing or other purposes do I need to reattach the ground strap and drive a ground rod?
Thanks
19,755
Hello,
Thanks
Like @DieselAddict said, ground it.
The reasoning is pure simple safety and logic.
There really aren't but two choices:
1. Drive (and test) the ground
2. As the human, YOU can be the ground (bad for your health)
Humans being mostly water and maybe on damp grass or dirt conduct electricity really well.
Your personal goal naturally is to stay alive and not be the conductor.
Elijah95
Certified Rookie
1,239
1,195
Georgia
Hello,
Thanks
I’m generally lazy, but after being bit by an un-grounded set, I now go ground crazy. Cheap insurance.
Ps the shock doesn’t give you superpowers sadly
nextalcupfan
506
NW Missouri
When I was doing initial testing after I first got my 803a I did ground it, though probably not enough.
I drive a piece of rebar into the ground about 6-8in and hose clamped some wire to it.
I DID have continuity to the ground from the set though.
ribs1
21
Michigan
I have a reliance pro/tran transfer switch. Can I just plug the generator into the power inlet box but not switch the transfer switch from line to gen? I am pretty sure the ground goes all the way through and is not switched?
I did have an electrician install this switch.
Thanks
SCSG-G4
PSVB 3003
3,378
Lexington, South Carolina
Thanks
Are you going to bet your life on it? If not, run your own ground!
DieselAddict
2,058
Efland, NC
Thanks
You are correct that the ground should not be switched. Making that connection would ground it.
I don't know if you run your generator in the same place all the time but just as a FYI, I have a ground rod driven where I work on generators that I use to ground them. Ground rods are pretty cheap and assuming you don't have rocky soil (like I have here) they are not too hard to sink. Well worth the safety factor.
