- 333
- 741
- 93
- Quincy, FL
After staring at my Deuce sitting in the shop for far too long I'm back at it and starting to go over her from end to end. Out of all of the usual things I expected to find I've only run across two actual issues. Slow release of the brakes (although they work perfectly) and what is shown in the photos below. Hopefully new soft lines will cure the brake issue but the door stop rod connection point on the drivers door is sheared off clean. I can't see past the window channel on the inside but I'm assuming that this part is welded on the interior of the door.
Has anyone looked inside of a completely stripped door and noticed if the stop rods connection point is in fact a welded on plate? I have a few ideas on how to make the repair but it won't look original by a long shot.
