I have a 53 M-37 have owned it for 15 years. Hasn't been driven for a few years. When it was parked it had a dead spot off idle. I just pulled it out of the shed to work on it. I purchased a new carb kit from Mikes carburetors. Polished up the accelerator pump and the bore. Checked the compression all 6 cylinders see 112 lbs. Pulled distributor cap set the points to .20. Put everything together and still have the dead spot. When i take the top of the carb off and push accelerator pump down it does squirt gas out but I just don't think the vacuum is pulling up. I can look down the carb with air cleaner off and no gas is being squirted out off a idle. Any help with this issue would be much appreciated
Thanks
Thanks
