Hmmwv radiator 6.5 non turbo, best option
Btharbold
13
Port Deposit, Md
Well, looks like its finally time to replace the radiator in my 1045. Its been weeping for awhile at the top tank, and getting worse now so...Is NOS OEM AM General the best option, or are there good replacements out there that seem to work well. Not looking to remove the hydraulic clutch at this time. I have seen some of the aluminum ones out there, anybody have any feedback on any of them? Appreciate it.
Brad
Mogman
10,217
Papalote, TX
I have had no issues with my Champion aluminum radiator at least in the 5500 miles so far, it cools really well, But it would not be a bad idea to take the old one and have a local radiator shop look at it first.
Btharbold
13
Port Deposit, Md
Was it a direct clean bolt in? Yea, seems like radiator shops are fading away into the past. All the ones that were near me have folded. Everything is throw away these days. I might keep the old one and see if it can be recored and have the tanks re soldered. But I do want to get a replacement in it for now to make it a quick turn around.
Mogman
10,217
Papalote, TX
Yes it bolted right in.
Mogman
10,217
Papalote, TX
Champion CCHVB
Not sure what turbo models it will fit, maybe someone will chime in on that.
Mogman
10,217
Papalote, TX
Could you share the Champion part number?
And do you know if there is a difference in the NA and turbo version?
It was posted that Champion was working on an extended radiator, the more people inquire the more incentive they have to act.
Btharbold
13
Port Deposit, Md
Installed the Champion radiator, the thing fit like a glove, all mounting holes were correct. It looks great, especially considering the $. Truck runs well, seems to take longer between fan cycles. Will see how it does in summer heat. With the money saved over an OE unit I replaced every hose and pipe in the entire cooling system. Installed OEM thermostat, replaced the rubber hoses on the cooling stack. Very happy with the product, almost afraid to say to good to be true. I know they are coming out of China at that price, but even the welds on these things look good. I would recommend at this point. Thanks guys.
TOBASH
3,845
Brooklyn, NY
I discussed this with RWH many months ago and he explained…
An ECV has a different hood mechanism and different mounts to allow for the longer radiator.
The civilian H1 turbo and duramax turbo use a shorter radiator and do just fine.
Without major adaptation and major parts purchase you won’t be able to fit an ECV radiator into a standard hood rig.
I recored my standard radiator with a four core dimpled insert on my supercharged civilian H1 and it seems to be doing fine.
TOBASH
3,845
Brooklyn, NY
Hummer H1 radiator and HMMWV radiator are different, the H1 inlet is farther to the drivers side than it is on a hmmwv.
Yes. True. But overall dimensions are the same. I have held both up to each other given that I own civilian and military units.
Steve is correct (as always).
Retiredwarhorses
4,444
Brentwood, Calif
I only say this because the website for champion I thought was a bit confusing on the application and part number…99.9 don’t know the difference and they don’t make an upper radiator hose to fit if you install the wrong one.
