MAK Marine Armor Kit question
Coug
4,323
Olympia/WA
So my M1123 had the MAK added to it, then stripped off before sale. It will has the heavy springs under it from the kit.
The question I have is do the changes they made for the MAK affect it's max load rating.
I was looking up the kit, and the 4 door version could weigh 3800 lbs. Truck only had a max rating of 4400 lbs load to begin with, so 600 lbs for 4 people plus gear doesn't seem realistic.
I'm wondering because even though my truck isn't armored, I tend to be a little heavy. Last time I crossed the scales with the BEOD and gear, I was at 9400 lbs.
I am about to add some heavy jack rails and skid plates underneath it, about 500 lbs worth of steel (yes, probably a little overkill, but it's all on the bottom so it won't affect my center of gravity negatively) which would put me right about 10k lbs, and the base M1123 is rated at 10,300 lbs.
I know the springs under it, at least the front ones, are for the M1113 trucks. 6000 lbs per inch compression rated according to what I can find online. Massive overkill for an unarmored truck.
Not sure the rear springs, but I'd imagine they are also from the M1113/M1114 trucks. A couple inches compression with the BEOD on fully loaded, but ride much nicer with that weight.
So does anyone know if they increased the weight rating in service with the MAK suspension under it or was the spring upgrade just to keep it from sagging so much?
Hummer Guy
807
United States Louisiana
From what I know, the suspension springs were upgraded to more heavy duty springs once they started getting the MAK Armor kits, as for the half shafts and other 12k parts, I wouldn't know.
BLK HMMWV
491
Pasadena California
you could always use a set of H1 factory aluminum jack rail/skid plates and save some weight?
BLK HMMWV
491
Pasadena California
I just spent $550 for a 20 foot stick of 3/8" 4x4" angle iron and a 4x8 sheet of 1/4" steel and I'm cleaned out for a while.
Wow.
I have a set of the H1 aluminum skid plates / jack rails in my yard that need a new home.
they are in the white as in bare aluminum . I was going to chop them up but went a different route.
I ended up making my own set of jack rails for the removable side steps and ammo can carriers and never used them.
