nyoffroad
- 682
- 93
- Rochester NY
I'd post up a pic but it would be a waste, considering it's sitting on the floor of my storage container. Oh well, maybe some day.
Wow, very cool . That's the best setup I've seen. Thanks for the pics.Ive got the regular 12k harbor freight winch mounted upside down behind the front bumper. I cut out the front flat license plate area and put a roller fairlead cover on it. It has a Daystar urethane winch hook isolator so the hook nestles in sideways and hides easy. I put the winch box remote mounted to the fender next to the washer jug. It's wired in direct to the front battery with the included parallel circuit breaker pack. I had to buy some additional wire and I sheathed most of it with some cheap mesh wire loom with heat shrink on the ends.
View attachment 859314 View attachment 859315 View attachment 859316 View attachment 859317 View attachment 859318
Hi can you show me some more pictures of how it's mounted underneath? ThanksIve got the regular 12k harbor freight winch mounted upside down behind the front bumper. I cut out the front flat license plate area and put a roller fairlead cover on it. It has a Daystar urethane winch hook isolator so the hook nestles in sideways and hides easy. I put the winch box remote mounted to the fender next to the washer jug. It's wired in direct to the front battery with the included parallel circuit breaker pack. I had to buy some additional wire and I sheathed most of it with some cheap mesh wire loom with heat shrink on the ends.
Hi how hard was it taking your front bumper off? I'm going to take mine off tomorrow.I modified a winch mount plate to fit tight behind the front bumper. Also mounted the winch upside down, trimmed the bumper, and gave the star some fresh paint. Works great. Its also the regular 12K harbor freight winch.
I really just made sure to measure it properly and cut it so the winch was centered on the plate. It's mounted to four holes I had to drill in the frame with a right angle drill and stubby bits I cut down. I'll see what I can get for a photo.Hi can you show me some more pictures of how it's mounted underneath? Thanks
