diesel_dave
- 285
- 63
- Utah
I installed all the parts that GP removed and I think I got everything hooked up correctly. The question now is how do I know if it is working? When the valve is in "vent" or "deep ford" there is no air whatsoever coming from the vent line that is teed off to all the various components. I even tried to trick it by holding the sensor cup under a bucket of water but that did nothing. Anyone know what is going on here?
I'd like to make sure it works before finding out it doesn't by contaminating all of my various oils with water. I think either a bucket of water isn't deep enough, engine RPM at idle isn't enough to create any pressure, or I've hooked up something incorrectly. I could apply a few PSI of compressed air to the sensor cup hose and see if that does something if anyone knows how many PSI I should be aiming for? I can also try to give the engine some more RPMs and see if that's the issue since you probably won't be idling through a stream. And finally, I am pretty sure I hooked up the hoses correctly but I guess I may have made a mistake reading the somewhat confusing install guide.
Any help is appreciated.
