- 333
- 740
- 93
- Quincy, FL
I'm slowly accumulating spare parts for my trailers and I've hit a wall on the wheel bearings for the M200A1 under my MEP-004A generator. The inner seal, spindle nuts and lock are the same as the M105A2 trailers. Unfortunately the wheel bearings are a different part number. The M200A1 TM lists the bearings as p/n MS19081-112. I've searched high and low for an NSN or cross reference with zero results. That number comes up as no record on both WB Parts and Part Target. I'm at a loss on this one.
Upon further research the race 7411377 also matches the M105A2.
Would it be safe to assume that the bearing would be the same? Hopefully the Timken SET408 will work for both the M200A1 and the M105A2.
Any help or guidance would be greatly appreciated.
Richard
Richard
