How to- MRAP Eyecon Light kit install on M923A2
kendelrio
8,983
Alexandria, La
So, I bought an Eyecon MRAP light kit from @MilStuffMike65 and decided to install it on my M923A2 "Big Bertha"
After receiving it, I realized there is a sever lack of information on the installation of these kits on anything but MRAPS, so I figured I would document my installation on Big Bertha to help those who come after me... if you have any questions, feel free to reach out.
The book that comes with the kit states one soldier can install in 8 hours, but it's better with 2 soldiers.
Between prep, modding brackets, figuring out how to mount and installation, it's taken 3 solid days so far. All thats left is to clean up the pass through I cut into the cab and storing excess wire lengths.
Also, I made some mistakes and had to take a few steps backward to correct them, so I hope this helps others from making the same mistakes.
So:
Day 1: Prepping and painting.
While all of the OG trucks are tan or camo, Bertha is black, and tan gear would mess my feng shui......
Painting brackets:
Taking the light bars apart to paint the housing to ensure I didn't get paint on any lights, lenses or important stuff inside:
Taking them apart does two things:
As stated, no paint on important stuff, and by not taping, you get good coverage in all of the nooks and crannies.
Also, you don't need to remove **everything**. If you follow the directions in the book for "light module replacement", you can take the lights out, tape off the ends of the connectors and tuck them back and get good coverage on everything.
I was originally going to paint everything matte OD green to set them off from the truck, but quickly realized there wasn't enough paint in 3 cities for what I need, so the decision was made to use high temp matte black.
After everything was painted, it was getting dark, so we wrapped for the day to allow the pieces to dry.
Day 2: Testing and layout on the truck
After everything dried, I wanted to ensure everything worked before I started cutting and drilling, so I laid everything out and used the batteries for the M37 for juice
The different components are labeled according to their location. For instance the drivers side light bar is referred to as the "Street Side Light Bar" and the connector end of the cable is labeled "SSLB". The search lights (which are remote controlled by the way!) are labeled "SSSL" and "CSSL" (Street Side and Curb Side Search lights).
The cables are all labeled to help with identification. For instance, the Street Side Light bar cable has a tag on it reading "SSLB", the Vehicle Interface Box has breakers on it, and the power cable for it is labeled "VIBPOW". Everything going to the Pass Through Plate in the cab has "PTP" at the end of the initials.
One of the confusing aspects was which end goes where, but after a little head scratching, I figured it out.
Once I had everything laid out, I connected the batteries, hit the master "On" switch... and nothing. No power to the control box.
After some serious googling and searching here in the site, I found one mention of a solenoid that needs to be energized in order to allow power flow to the box. In an MRAP, there's a plug that goes to the main breaker box that sends power to the solenoid when the master switch is on. That was bypassed in the other thread by bypassing the small white plug on the VIB and putting a toggle switch sending 24VDC to the solenoid.
I opened the box up to look at it and realized the ONLY purpose of the solenoid was to energize the breaker bus bar.
So out came the trusty screwdriver (at this point my sweet lady @IRIS_Always thought "Its brand new and he's gonna tear into it!?!?!" and had to walk away) and the solenoid went away....
I reconnected everything and angels sang!
That process easily ate up 3 hours, so hopefully if someone finds this thread, it'll save them that time.
I decided at that point to do the "easy" install of the "Front" and "Rear" light bars. Being as I won't need the rear light when I have the cargo cover on, I decided to mount it facing forward.
To mount the front light on the bumper, I had to remove the top shackles from my bumper. I took the long bolt out and reused the short bolts from the removed shackles to rescue the back of the bottom shackles.
I also worried about hood and hood locking bar clearance, so before I made anything permanent, I checked the gap:
It *barely* touches the bottom of the light bar in the front and the back is good to go.
The kit comes with a "spacer" bar with the bolt holes on it, so using that as a template, I drilled the holes and mounted the light.
Next was the "Rear" light on the roof. I used the bracket and drilled into the cab to mount it, using LOTS of silicone to seal it. After mounting it, I realized the MRAP apparently has an angled rear that it mounts to and the light wasn't level because the bracket is made for that angle.
So... down it comes and I mark 2 new holes in the bracket to mount it level and using my trusty cutting blade, lopped off the top of the bracket to make everything level and pretty:
So after about 6 hours, I had working lights and 2 of them installed.
More in the next post.
kendelrio
8,983
Alexandria, La
Next was mounting light bars:
I had found this pic online of the kit mounted, but didn't realize the intake had been modified to allow the rear bracket to not hit it....
They had also fabricated all kinds of other brackets for the installation. Being as I'm a "shade" tree", I had to get creative....
I decided to flip the rear brackets to allow clearance for the intake mushroom.
Then after measuring, I knew something would have to be done to mount the front bracket, as our cabs don't have 43" inches to work with, so I decided to cut the front bracket down to the flat plate and use bolts and spacers mounted to the interior of the light to level the lights.
Again, out came the trusty cutting wheel...
I made spacers using electrical conduit and fender washers inside the housing and out to ensure everything is secure.
NOTE: To flip the brackets, make sure everything is facing the correct way before you start cutting!
Once I had the brackets cut, I used them as templates and drilled into the cab to mount them. It is easier after drilling your holes to mount the front bracket to the light off of the truck because you have to open the housing and move some of the transformers etc to drill your holes and install the washers and nuts.
After the light bars, it was time to install the search lights. Once again, the angles on the MRAP bit me in the butt because they are designed to be mounted to the front windshield frame, which is angled on an MRAP, but vertical on our trucks.
After thinking it through, I decided to mount the lights on top of the cab. To do that, I had to modify the brackets, so out came the trusty cutting wheel....
**note** I know we are all grown people, but PLEASE use PPE. Even with long sleeves etc, my arms and legs got very abused during this process. I also had a cutting wheel disintegrate and debris flew everywhere, so had I not had a face shield etc on, I would have been severely hurt.
The modified brackets were silicone and mounted:
After mounting both brackets, the search lights were mounted:
After that came the pass through plate and figuring out where everything went. There isn't a lot of room in the cab, so I had to improvise.
I'll probably post that tomorrow as there's some cleanup I want to do before I post pics.
marchplumber
3,139
Peoria, Illinois
LIGHT EM UP, Sir!!
kendelrio
8,983
Alexandria, La
Thanks all...
Now...
Mounting the interior stuff.... To say our trucks don't have a lot of extra room for accessories is an understatement. I was also having to work around the other wiring I've installed for the convoy lights and overhead console I've installed...
After measuring for the pass through in between the seats and making sure I had clearance for the connectors, I decided to mount the Vehicle Interface Box behind the passenger seat head and the control box to the ceiling.
I initially tapped the control box bolts into the roof liner bracket, but that's kind of sketchy so I'm going to get some longer countersunk bolts and fender washers and mount through the roof.
That completed the install.
Lessons learned:
There are virtually no nuts included in the system, and a majority of the bolts are not the right size you'll need to mount the kit in a M923. Lay out and plan your install and determine the hardware you'll need. I made way too many trips to Lowes, whereas had I known this, I could have only taken one trip. Also, you will end up with extra bolts, washers etc. Don't be afraid to repurpose them.
The wiring isn't that complicated. Once you figure out the labeling method, it's simple.
Make sure you have a helper. The side bars are about 20 lbs each and the front bar is about 35. They are awkward and an extra set of hands goes a long way to making it easier.
Planning the location of the install before drilling cutting saves you time during installation.
PPE- as I stated above, even with full PPE, I got cuts and knocks, so please be safe.
If you have ANY questions, feel free to reach out!
Various pics of the install:
Two of my buddies helping me
Front light bar power wire is run along the inside of the frame rail
Search lights and side bar lighting wiring
Lit up
TheQuaker
944
Eagle Twp, MI
Ken
Awesome job on the install and figuring out how to adapt the kit to your truck! Looks great and you are obviously happy with the results.
But...I am cringing at all the holes you needed to drill into your hard top.... :cry:
YMMV...so to each his/her own and you know I am 100% behind you. She's all yours so have at it as you see fit. But I am stroking out here a little... :)
kendelrio
8,983
Alexandria, La
Ken
Lol. Yeah, that was a major hang up for me. I didn't want to do it either, but I figured it's permanent, so... 🤷‍♂️
FloridaAKM
392
Gainesville, Florida
I got one of those kits from GL back a few years ago & had to ship it to Florida. After it arrived, I found out that you can't install it & keep the on road tag, so it sits in the original cartons it was sold in, inside of one of my shops.
One way to get out of the work of installing it. I have seen those parts & pieces sold off @ the military meets every so often for big $$$!
Great job & pictures of the installation, thanks!
FloridaAKM
392
It was explained to me that if I changed the paint job or added a business logo to it or even added the MRAP lighting system, they would pull my tag & change to title to an off road tag only.
The truck had to stay as it was when it came out of the military to continue with a title & tag to use state or county owned roads.
I think I have opened a can of stink that should have been left closed & sealed dealing with this issue.
kendelrio
8,983
Alexandria, La
It was explained to me that if I changed the paint job or added a business logo to it or even added the MRAP lighting system. they would pull my tag & change to title to an off road tag only.
Oohhh. Gotcha. Florida rules. 🤦‍♂️
kendelrio
8,983
Alexandria, La
Point that truck at a dark stage and you have a rock concert! Have you heard anything from NASA? I’m sure they can see Bertha from the space station…
Nice job fitting those lights to your 5ton. I especially like your solution to the solenoid issue!
That one was a head scratcher for a minute until I could open it up and see the power flow...
