Best Mods to Get a CUCV to go 75mph?
4,727
I went from 31's to 35's. That helped a little on speed, but it slowed down a bit. I added a turbo. That helped put me back where I was. Then I went up to 37's. That allows me to run 60 now without too much drama. But it's still revving to high IMO. I've got a 4L80e in a donor truck I need to swap into it.
4.10's would be a compromise. But I'm not willing to give up the pulling power.
Keith_J
1,316
Schertz TX
This is why I am doing the turbo before 4L80E transplant. It only adds 50 Hp but nearly 100 foot-pounds of torque.
Engine torque curves track volumetric efficiency curves. Adding a turbo only changes charge density, the volumetric efficiency remains the same. Power is based on mass flow rate.
chevymike
460
San Diego, CA
You can fit 35" tires without a lift but there is not much rear wheel travel before you hit the wheel wells. Here is 35" on Hummer H2 wheels and no lift. You can see the tire is already tucked up some.
Here is the rear with a 2.5" shackle flip, which gives you back full travel without too much extra height.
The front was still stock height and needed a 2" lift springs to get is more level but it cleared with just a minor fender trim. Never took it offroad but street driving, no issues.
Before
After
By comparison, this is 33" tires on stock suspension. No clearance issues.
ssdvc
639
CT
What is antiquated in stock form? My old K5 would do 75/80 no prob.
Now lifted sure, the steering is squirrelly when you hit the brakes up or a bump but that's all fixable with money.
Both of my trucks even heavily modified will hammer down the left lane as fast as you want to burn the fuel. It's really not a problem.
There is nothing inherently wrong with a straight axle Chevy from keeping up with modern traffic. The engine and lack of gears is the only limiting factor.
RGR that Skinny. If you modify a few things, I agree you can run a higher speed with minimized concerns. I was just talking about a stock truck. I have done 75 (in short bursts) with my 09, but she is stock all the way. Precise road handling is just not there. I have to pay a lot more attention when at that speed in my truck.
Skinny
488
Portsmouth, NH
I will say two things really dial back the handling. Stock height and age springs. The clapped out reverse arch front springs at the age they are at suck.
The other huge one is stock push pull steering. I had it on my M1031 in stock form and lifted 4". It was God awful either way. If the truck bounced from a bump it would pull you in one direction.
If you hit the brakes hard it would always steer you into the ditch. Even worse with no sway bar or soft springs.
Crossover is like driving a sports car compared to push pull. Especially with a new tight steering box that gives you good assist. I can drive both trucks one finger down the highway at 80mph. It has zero bumpsteer and turns very sharp in parking lots.
I wish I did overdrive and crossover ten years ago.
If you are stock height I don't think it fits so it's a commitment for sure.
Do you get drive line vibes at that speed with the 09? I imagine the short rear driveshaft doesn't like that speed.
Mainsail
1,583
Puget Sound, WA
Several years back I was commuting to the Bellevue area, and on my way back to the ferry terminal one evening I was in the left lane of I90 going with traffic, so about 65MPH. As I was approaching an onramp that feeds in from the left (idiot road designers) a car entering the freeway and the car on the freeway decided to play a game of You-go-no-you-go and they both pretty much stopped.
The weird part was that i was paying full attention, but the suddenness of the speed change occurred too quickly for me to react properly. So I went from humming along nicely to TOO-MUCH-SMASH! in about half a second. Like Elwood Blues; both feet on the wide pedal max effort braking.
I have to tell you, the noise and smoke the M1009 makes with all four wheels fully locked from 65MPH is as impressive as it is unforgettable.
The backs locked up first, then the left front, followed about one second later by the tardy right front. That put the truck into a leftward trajectory. I will point out that there was 100% no way the mighty CUCV Blazer was going to stop in time- even with the brakes fully locked I was still going to hit either or both of those vehicles at totaling speed. Roll the ambulances now, cause this is gonna be messy....
The leftward trajectory that resulted when the right front disk showed up late for the party, while unplanned and unanticipated, was in its own way beneficial. Even though I was sliding towards the soon-to-be piles of twisted metal, the nose of the truck was pointed towards a clear space between those cars and the left jersey barrier. All I needed to do was make the truck go in the direction it was pointed instead of the direction it seemed content to continue.
Having some experience with old fashioned do-what-you-tell-them-to-do brakes (no antiskid) I quickly released the pressure I was applying to the brake pedal, the wheels unlocked, and the truck shot through that opening still traveling about 45MPH, blowing by those two cars like they were standing still, which they pretty much were.
No worse for the wear.
  • Like
Reactions: 98G
ssdvc
639
CT
Actually, no vibrations at all when traveling 65 to 70 and even at the occasional 75mph. When I first got the truck, she wanted to wander quite a bit when on the highway. I replaced the drag link and now she goes where pointed, for the most part. When everything is functioning correctly, I have found my truck to be very solid, tight and vibration free. I have a friend of ours coming over and doing the rear main seal and the transmission rear output seal on the 7th. Once that is done and with the newer Vacuum Regulator for the trans in place (thanks Skinny !!) I am hoping she will shifting as she should and running even better than before.
Skinny
488
Portsmouth, NH
That's pretty good. Imagining going over 55mph stock is funny because of the difference in gearing. I felt like the engine was going to explode with the 4.56s.
Not a problem! Hope it all works out. Don't push the back too far.
ssdvc
639
CT
RGR. I am going to experiment with the regulator, starting in the middle of the adjustment and working from there. It will still be a few more weeks before I can get to it.
dubiousgarage
Northern California
Before
After
Super helpful Mike. Great photos.
How wide were the 33’s? 11.5?
and the 35’s? 11.5 or 12.5?
I found some interesting new narrow tires oot
Kenda Klever
33x10.50R17LT 121R E
35x10.50R17LT 121R D
chevymike
460
San Diego, CA
Kenda Klever
The 35" on the H2 wheels (17x8.5) were 12.5" (35x12.5-17)
The 33" ones are (wheels 16x7) 255/85-16. Then end up close to 10" wide. The equivalent in a 17" wheel will be 255/80-17.
