KallyLC
- 146
- 33
- Atherstone, UK
Got a hard shifting issue so I took a look at my vacuum lines and found a couple of likely culprits, some rotten hoses and this thing that connects to the vacuum valve on the IP. But the question is, what is it?
The TM helpfully just lists it as 'adapter' and, the NSN turns up nothing.
Does it actually serve any kind of higher purpose, or is it simply just a fancy-looking adapter that can be deleted and the hoses plugged straight into the vacuum valve?
Thanks.
Thanks.
