Hey y'all...gotta 67 M715 still with the original Tornado...just paid Willis America to rebuild the vacuum/fuel pump and I cleaned the Holley one barrel...but it is flooding badly...I checked the float and the vacuum slide behind the float and both seem to work fine. Anything I'm missing? I've already bought two old Chevy stovebolts but I thought I'd give the Tornado one more shot...I had it running pretty good for a bit but it didn't last long
1) Does this have a mechanical or electric fuel pump? What’s the fuel pressure at the carb? Could be way too much fuel pressure.
2) What is the model carb? I’ll see if I can find anything on it.
3) What is the float made of; brass or that synthetic material? The float could be bad or the float drop incorrect.
4) Did you replace the float needle valve & seat?
5) Sometimes the float pivot pin and spring (if equipped) may have gotten hung up.
6) Is there a fuel return line & us
I can’t believe vacuum would make it flood - vacuum simply indicates ‘load’ for the lack of a better word and load means a demand for more fuel - fuel is regulated by the fuel bowl needle valve and fuel pump.
I need to think about this some more.
