- 333
- 740
- 93
- Quincy, FL
Easiest is just leave it without anything connected.Maybe you can help with another question. I have one of the WND-7-28 dual output PTO's here. Is getting rid of the rear accessory drive as simple as locating a plain rear cover and swapping it out? The parts manuals make it look that way.
No. It's much more involved than that. Just leave it like NDT suggested.Maybe you can help with another question. I have one of the WND-7-28 dual output PTO's here. Is getting rid of the rear accessory drive as simple as locating a plain rear cover and swapping it out? The parts manuals make it look that way.
Have you ever done it? Maybe you can explain to us tree shade mechanics what exactly is involved...?No. It's much more involved than that. ......
I posted my rebuild of several PTO units here, including the dual shaft one mentioned.Have you ever done it? Maybe you can explain to us tree shade mechanics what exactly is involved...?
I tried to find my old rebuild post here but couldn't find it. This new site sucks about that. We used to have all our pictures and posts in a private list you could access. Now nothing. I'll try and see if I backed it up on my computer somewhere. At least some pictures if I'm lucky.I posted my rebuild of several PTO units here, including the dual shaft one mentioned.
Nice pics Greg, but maybe you should read post #4 again... The question wasn't about rebuilding a PTO, but precisely if on a WND-7-28 you could simply swap the rear accessory drive for a bearing cap (cover), like the WN-7-28 uses. To that you replied:I posted my rebuild of several PTO units here, including the dual shaft one mentioned.
So obviously we want to learn what all it takes to do that.No. It's much more involved than that.
My bad. I misread the post. You can make a dual shaft into a single shaft and a single shaft into a dual shaft with the correct parts. You really need to totally disassemble the PTO though. Check all the bearings and bushings, and replace whats needed. The shop manual gives very good step by step instructions, but not so much on pictures. If I can ever find my post, I go step by step on the rebuild. I still haven't found it though. I didn't back it up on my personal computer either. Or if I did it got lost during one of my computer crashes. I've had several total crashes since 2017. Two due to malware and trying to clean out my computer. I've since backed everything up, but the last time was in 2020, so the rebuild would have been lost. Right now I don't have time to make up another step by step rebuild. I'm still trying to get my new shop finished. I can only work for about three hours before I'm too tired and have to stop for the day. Getting old sucks !Nice pics Greg, but maybe you should read post #4 again... The question wasn't about rebuilding a PTO, but precisely if on a WND-7-28 you could simply swap the rear accessory drive for a bearing cap (cover), like the WN-7-28 uses. To that you replied: So obviously we want to learn what all it takes to do that.
Well, I finally had the time to dig out my old PTO and look at it.My bad. I misread the post. You can make a dual shaft into a single shaft and a single shaft into a dual shaft with the correct parts. You really need to totally disassemble the PTO though. Check all the bearings and bushings, and replace whats needed. The shop manual gives very good step by step instructions, but not so much on pictures. If I can ever find my post, I go step by step on the rebuild. I still haven't found it though. I didn't back it up on my personal computer either. Or if I did it got lost during one of my computer crashes. I've had several total crashes since 2017. Two due to malware and trying to clean out my computer. I've since backed everything up, but the last time was in 2020, so the rebuild would have been lost. Right now I don't have time to make up another step by step rebuild. I'm still trying to get my new shop finished. I can only work for about three hours before I'm too tired and have to stop for the day. Getting old sucks !
Thank you.Thank you for taking the time to look into this & post a definitive answer!
" There is no shame in being wrong, only in failing to correct our mistakes." - George SorosI was wrong.
