I went on a 125 mile shakedown run this morning, I do have a few minor issues.
One is the thermostatic fan switch is set too low, it is bucking heads with the thermostat, at 70 and above the fan comes on at 200 indicated then drops quickly to around 195 and just sits there as the thermostat maintains temp and the fan just runs, not doing much for my mileage although turning 2300RPM at 75MPH is much less distracting than the old 2900RPM at 60MPH.
The 6L80's adaptive programming started to settle down the shift points, now it is time to try and load a Cadillac 6L tune and get the manual shifting to work, I am going to consult with EFILive first about my concerns.
The oil pressure indicated 45PSI at 2300 RPM hot and around 30 at idle hot, wish I had thought about installing a HP oil pump when I replaced the oil pan, but this will be fine, one reason many of these run lower than average oil pressure is when they developed the 6.5L they added jets in the crankcase to oil cool the pistons but there is a limit to the torque that can be delivered to the oil pump with the small cam gear and 5/16 hex shaft driving the pump.
