CommoChief
- 40
- 28
- Sayre, PA
Has anyone come across locking door handles for the HMMWV...?
I believe Federal has some that lock inside and outside or just outside. They are pretty spendy but cheaper than a door. I like the idea of being able to lock myself in if needed. When I get to the point of installing my doors I will have a set on themHas anyone come across locking door handles for the HMMWV...?
Thank you...we will check out Federal. Having the option to lock from the inside is the way to go.I believe Federal has some that lock inside and outside or just outside. They are pretty spendy but cheaper than a door. I like the idea of being able to lock myself in if needed. When I get to the point of installing my doors I will have a set on them
Get the $5 lock outside hadles and attach a small rubber wedge to a wire on the inside. Just push it in the gap to lock from inside.Thank you...we will check out Federal. Having the option to lock from the inside is the way to go.
Can you explain this better? Do you have a picture?... attach a small rubber wedge to a wire on the inside. Just push it in the gap to lock from inside.
Nope. I dont lock mine from inside.Can you explain this better? Do you have a picture?
Gotcha, I was hoping for a solution like this but for people who don't have the locking door handles. Oddly I only want to be able to lock the door from the inside but not the outside. I'm sure there is a way.View attachment 866730
I just grabbed something from garage. You can stick just about anything in this gap to lock the door from inside.
And, yes, i just tried this. That rubbermaid shelf mount dies lick the door.
decisions...decisionsI have one truck with the inside/outside locking handles, may be useful in a mob situation, under normal circumstances, someone opens my door I would just let the Judge take care of them, nestles quite nicely between the seat and tunnel, also saves me time because otherwise I would have to pull the Sig from my front pocket or the Colt 1911 from my back.
