MattNC
- 271
- 63
- Raleigh, NC
I would be interested to see how fast it reacts, your numbers are very low, when you are running at highway speeds and lift off the throttle it should drop very fast to around 300 degrees otherwise it is being influenced by the manifold (tip of probe not in the middle of the stream or cheap probe)
The DuraVee acts correctly, the Detroit only drops to around 450 degrees and then only after a minuet or so to 300 which means the turbo housing is effecting the reading, I suspect I am closer to 1000 degrees at 75MPH, the probe was shorter than I need to get into the middle of the stream so I have ordered another.
On the DuraVee you can rock the throttle back and forth and get an immediate response with very little delay, half second or so
Alright, as promised I finally got some videos of it running. They are a bit long, but I just left the gopro running and figured its more data. I'll post some pics of the EGT probe location as well.
My ongoing restomod M998ish project
I thought I’d share my restomod project that’s ongoing and progress so far. I use the truck a lot from the beach, to the farm, camping, Home Depot runs, etc so I made the truck to do what I want it to do while hopefully honoring the 30 year old military vehicle it is. Base vehicles- 1993 M998...
www.steelsoldiers.com
