FMTV Lug Nuts
Cave Johnson
84
Texas
Digging in to this, I think this is useful, these being a non-metric item on the vehicle. All the mirror and door hardware is metric. There are quite a few places you can obtain these if you know the correct flat to flat, stud diameter, and threads per inch, which I sorted out per above.
Sunday morning scold for dropping an F-bomb (in a forum catering to vehicles designed to participate in the formal process of killing people)
Makes me feel at home really. My father is a retired officer and absolutely condemns use of curse words and has for my entire life at the very least.
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
It'd a standard budd nutt for most of them.
Wa2006
Wa2007
At napa for the main lugs.
The lug nut for the ctis is a dual exterior nut. Also common commercial truck stuff.
Cave Johnson
84
Texas
Wa2006
Wa2007
Exactly. They built these to share common components with commercial vehicles so they would not run in to the previous problems related to aftermarket supply of parts.
But sometimes it's a bit obtuse.
simp5782
9,384
Mason, TN
Ha no they didn't. Only about 10 parts on the whole truck have a commercial equivalent.
These trucks were based on their own design and for the military only. They didn't take an existing freightliner or mack design and incorporate it like AM General/Jeep/kaiser did.
Cave Johnson
84
Texas
Intent and final result vary, but the point was drive train and other components. Things that wear out and needs to be replaced an readily sourced.
simp5782
9,384
Mason, TN
Ha no. You will have to explain how you get to that conclusion? Planetary outers are nothing like anything commercial. So lug nuts, u joints. Driveshaft yokes. Cause they didn't have a choice. Transfer case isn't common at all.
Cave Johnson
84
Texas
Ill get a quote from the retired English officer who was running part of the sealy BAE plant next time Im out at my farm and he rides by on a horse.
coachgeo
3,462
North of Cincy OH
Think "commercial" is loosely defined........ well it got twisted to be loosely defined maybe. Found long ago the PDF that was the explanation/impetuous of the Paradigm Shift military went to in vehicle design/selection ....... aka... more commercial parts.
Likely lawyers for firms that build military equipment figured out work around(s). Like the cab airbags on the FMTV's by PowerPacker.... they fit the "commercial" definition likely only because PP says they can be utilized/available for sale to manufactures of other specialized "commercial" trucks so as large fire trucks etc....... So "commercial" became NOT to mean "commonly used / commonly found parts"...... but instead to mean the part(s) coullllllddddd end up on some other commercial type vehicle if a vehicle manufacture wanted to utilized it in their builds.
olly hondro
521
tucson AZ
I am currently up to my eyeballs in discussions of Commerciality with our Government. The availability for commercial purchase, and onesey-twosey examples of commercial use are necessary but insufficient justification. The end use has to be a typical, usual application for commercial designation.
