So.... I have a problem.
I like cranes.
I put them in everything apparently. (How do I fit one on a ferret and a hmmwv?)
I've had this one for a while sitting around. And given how time to time I lift heavy crap working on transmitter sites, the cucv is a good place to put it. I had thought about mounting it on the trailer I just rebuilt. But that would add to tongue weight. And eat up deck space. Plus trailers aren't that great off road. I built a frame out of one left over section of 5" c channel. I milled the corners to allow the bolts to sit flat when you tighten them down. Also it just worked out perfect that where I needed to drill the holes to keep the channel in the bed slots means I can tighten the bolts underneath without any help or a wrench up top. All of this is reversible as well.
Crane has up to 11ft of reach and 850lbs of lift capacity out there. The retracted capacity is 2450lbs.
Got a few other ideas and upgrades in store for the cucv.
View attachment 867274View attachment 867275View attachment 867276View attachment 867277
Sent from my SM-G965U using Tapatalk
