Ronmar
- 7,246
- Port angeles wa
If you are missing the other smaller device in the above pic that Ohiobenz posted, that is an instrunment shunt, used to measure current flow. It is placed in the main ground line between battery and starter and can measure crank current and total alternator output back into the batteries. The two large leads that attach to it can simply be connected together and insulated…
