B-Dog
- 289
- 63
- Denver, CO
That reverse light bezel is awesome!
The headlights are already done:
Sean:
Chad:
Sean:
Chad:
Yep see those! We were talking about turn signals and tail lights. By the way before you go buy and cheap Chinese headlights for 50 bucks go watch the video from headlight revolution on YouTube. Most of those so-called cheap Chinese headlights are complete crap. I managed to find a set of truck-lite brand mil-spec LED headlights for a good deal.That reverse light bezel is awesome!
Sean:
Chad:
.I got my drivelines back from the shop. Had it done at Fort Wayne Powertrain. In Fort Wayne, Indiana. An old timer helped me unload the shafts. took one look and knew they were 1610 joints. Asked if the yokes on the truck were full or half round. Despite having the "D" stamped on my ID tag, they were out of balance. They spun them, balanced them and painted them for ~600 bucks. Had them back in 3 days.
Getting them out was a huge pain in the arse, even with the u-joint tool. It took a LOT of force to get those to budge.
Pro tip for working on these... I had a cheap wooden movers dolly I got from Tractor Supply. I dropped 2 regular jack stands on it and set the driveline on the stands. One stand was almost fully extended, and the other slightly lower. I rolled the whole thing under the truck, and getting it back on the truck was not so much of a struggle (except for getting to those grease joints after it was in).
your truck ate a Steeler cow embryo?.....Look at these photos and help me ID this piece of metal stuck to the engine oil drain plug. Almost looks like the tip of an automotive seal pick. But it twists like a cows horn.
I’m afraid that may be the case.your truck ate a Steeler cow embryo?
Full tank of diesel = STRUCK IT RICH! Woo-hoo.I got these two ladies in on Monday. I rolled them off until the storm passes and I get a moment. One had a full tank of diesel so WINNING!
View attachment 868548View attachment 868547
What years? Winches? How close are the Serial / Registration #’s ? TomTime & I have 1083A1’s and our serial / registration #’s are 2 digits apart.I got these two ladies in on Monday. I rolled them off until the storm passes and I get a moment. One had a full tank of diesel so WINNING!
Very nice that's the same handles I got. Haven't installed them yet because I'm looking for a day where I have enough time to do it all in one shotUpgraded the drivers door handle today. Thanks to all the brave souls that have gone before me on this and posted youtube videos! It made my day much easier. The biggest headache for me was that my truck came stock with the door components switched sides and inverted so I had to create all new door rods with no template to go from so the fitment exercise was really time consuming. Other than that it was less challenging than expected. I do have to say that moment of cutting my door panel with a jigsaw - the point of no return - did raise my heart rate a bit but the trimark door handles are really forgiving in terms of fitting and the faceplate is nice and wide so it gives good “oopsy” coverage. Oh yeah, I was able to avoid cutting the 4” hole int he back of the door, not sure that it really matters but seemed like a lot of meat to cut.
Interior
How much per mile did you have to pay to get them hauled to you if you dont mind ?I got these two ladies in on Monday. I rolled them off until the storm passes and I get a moment. One had a full tank of diesel so WINNING!
Well, to be honest, I don't know.How much per mile did you have to pay to get them hauled to you if you dont mind ?
Thanks for the info i was curious what fuzzytoaster paid for that stepdeck in the picture cost him to move his 2 trucks .Well, to be honest, I don't know.
I have a former client (owned by my step brother) that is a very large steel fabrication business. They make large bedding boxes, snow pushers, and what not. Due to the size of the stuff they make they started their own shipping division, so that they could pack other freight into otherwise empty steel boxes to maximize the loads.
To make a long story shorter. I asked them to quote the freight for getting it delivered to the steel plant because they have a huge 30 ton overhead crane they could use to drop it on my LMTV. (that was awesome BTW, I'll try to attach a vid.) Edit: Guess not....
I've worked in IT for nearly 30 years now, and I've provided a ton of help and advice to my step brother for his business. We built a huge wifi mesh network that covers the whole campus, and installed security cameras everywhere to cover the weird things that employees tend to do, and I've given him a bunch of help and never charged him. They picked up the tab for the hotshot, so it was free to me.
The best Veritread quote for the nearly 1000 miles was $1350, and before they decided to pay for it, my friends at SteelMart expected to be able to get it for a couple hundred dollars cheaper than that. I hope that helps a bit.
.I installed little 12 volt LED panels under each door and three in the toolbox under the top front edge and under the left and right edges that face inward halfway down in. All of them will be activated by a door jamb switch
Sent from my S62 Pro using Tapatalk
