Kenneth Cole
- 41
- 28
- Wapiti Wyoming
Hi
What would be the best brand of glow plugs for the Humvee?
Ken
Ken
If they are non-swelling, why do they have a tapered tip to reduce swelling?How about these GEP18002668 glow plugs from HPG? It says:
" REVISED GLOWPLUG NON-SWELLING AND LONGER TIP FOR ELECTRICAL CONNECTOR END, ENGINEERED IN 2012 DURING P400 PRODUCTION AT AM GENERAL. HAS SPECIAL TAPERED TIP TO REDUCE SWELLING ISSUE. MADE IN GERMANY."
Hummer Parts Guy | Error
www.hummerpartsguy.com
Has anyone tried those? Is there another part number/ brand that it may be sold as? (Bosch?)
I seems that the so called non-swelling ones (perhaps the AG15? and also Kaskar?) have been discontinued and this may be another design trying to replace it? (thread from 2017 below)If they are non-swelling, why do they have a tapered tip to reduce swelling?
HPG in offline for some reason, it may come back up soon, or not who knows.@T9000 this link is broken, there is not a base web page even, can it be removed?
Never, unless I am troubleshooting a problem.How often do you guys check your glow plugs?
In the fall, I will remove at least one plug and verify it looks "reasonable". (Not swollen, not damaged.). If in doubt, it gets replaced. At $8 a plug, engine or start box damage is a LOT more expensive.How often do you guys check your glow plugs?
I've personally only seen 10mm plugs as Chinese counterfits. All the US plugs are 3/8" hex. I'm not against Chinese manufactured parts, as long as they clearly label it as such... but you counterfeit something, I'm calling it like I see it -- garbage meant to deceive.. See 10mm glow plugs, run away.. and buy the real thing.Are the Chinese making any with the 3/8" hex or do they only make them with 10mm?
I had received a set of supposedly U.S. issue plugs and the did look good (no numbers on them) and when I found they were 10mm I did not use them. They were also more on the shiny than the real Wellmans. Pure junk coming for the Chicom.
