VBsurfer
- 141
- 33
- Heathsville, Virginia
Thanks! Yup I haven't had as much time to work on it since I got it but been working here and there, right now trying to get all the electrical connections setup correctly that were not connected back when the previous owner was working on it. I'll check that bleed valve on the secondary fuel filters, he said he checked and it was good there, I opened up the fuel cut off cover and the "jesus" clip was missing so I got one of those. The alternator cables were off and the ring connectors are broken so I got some crimpers and new cable and ring connectors to replace them. Had to redo the battery terminals as well. Hope to get some time this weekend to work on it but it is going to be blazing hot out here! Thank you for all the suggestions i'll keep posting some pictures as I go through this.Nice truck! I'm curious to see how it turns out for ya. I think dirty fuel is out of the question, but a good way to check for flow and air is to turn the power on so the in tank pump is going, open up the bleeder valve on the secondary filters. Should have a good steady flow. If not, either the primary is plugged or if there's bubbles, there's air in the system. I don't know what the other owner did or didn't do, but I would do all the easiest and cheaper options before moving to the harder and expensive options. Hopefully it's not IP related, but I'm just hoping for the best for ya, lol.
