Horn doesn't work
mgFray
992
Southern Minnesota
Was wondering if someone had a point to diagnosing what might be wrong with the horn on my M998.
I looked in the service manuals and didn't see any flow charts on checking the horn wiring.
So far, I've checked AT the horn. I've got 24V where I should. The other line has no voltage (or -). I tried to check it with someone pushing on the horn button and nothing changed.
Wondering what I should do next? I assume at this point either the horn switch isn't grounded property, the horn switch is bad, or the column connection is bad, or the wire from the column to the horn is bad.
mgFray
992
Southern Minnesota
There is no power to the 24V line unless the lights are on.
I've had no horn since I bought the rig, and as I said, best I can tell it's not getting ground (-), but is getting 24V.
Milcommoguy
2,362
Rosamond, CA
You answered your problem in the last statement
Wondering what I should do next? I assume at this point either the horn switch isn't grounded property thru the wiring, up the column, to the button, thru the button when activated with the return ground at the column, with a wire attached to the column making sure it is grounded. or the horn is bad?
Just saying. Light switch to SERV RUN, pull leads on horn. Find the one with 24 volt to ground. I think it is #26 ?? Reconnect to horn. Use a short test jumper to other horn connection to ground and be ready for "beep beep". Follow your last statement to remedy the issue.
Funky horn button can be a problem, CAMO
Bulldogger
697
Quantico VA
My horn didn't work at first. I jumped 24V to it straight from a good source, bypassing the button. It crackled to life after some intermittent grumbles and has worked fine since. Try giving it a jump start!
BDGR
TOBASH
3,845
Brooklyn, NY
BDGR
Interesting.
Mogman
10,221
Papalote, TX
BDGR
The 24V does not come from the button, the button is the ground side.
Mogman
10,221
Papalote, TX
Like you and others have mentioned, it could be the button, you can pop the button out after removing the snap ring and try shorting that lead to ground, there is also a ground wire to the steering column that could be "broken" so use a good ground then if it works try grounding the lead to the steering column itself.
Mogman
10,221
Papalote, TX
OK, I just woke up,,,,
There should be 24V on BOTH sides of the horn until the button is pushed, if you only have 24V on one side the horn is open (bad)
Coug
4,580
Olympia/WA
Since it's harder to check with the wires hooked up, find the hot wire, make sure that one is plugged into the horn. You should still see 24V on the other horn wire because as pointed out above, the horn button is just a ground.
If you have voltage coming out of the horn, try grounding it and seeing if the horn makes noise.
Sometimes corroded electrical connections will show voltage, but not allow any current to pass. Or the horn could be internally shorted allowing you to see voltage on the output but not actually work.
papakb
1,194
San Jose, Ca
Take a look at the side of your steering column up under the dash. You'll see a connector on the side that's the ground return line from the horn. If you ground that connection and the horn blows your wiring is OK and the problem is in the colums or the horn button itself. There's a beryllium spring contact inside it that makes contact with the lead running up to the button that has a habit of breaking off. It's easy to replace, just 2 screws. The new one comes with a little tube of grease to lubricate it. If that's good then the problem is the button itself. Corrosion can cause it to not make contact with the steering wheel. Again, an easy fix, just a simple retaining ring that will let the button slip out of the steering wheel after it's removed. You can check the buttom with a multimeter to see if it's still makes contact between it's lead and the buttons case. This is the same horn button used in the 151 but it's only got a short wire on it instead of the long one used in the jeep. Easy to shorten up if you have one.
mgFray
992
Southern Minnesota
thanks, I'll start with the 24V check on the horn, then move up to the column switch. (Need to replace an ABS sensor on my jeep first.. ARGH.. I just wanna work on the HMMWV.)
Hummer Guy
819
United States Louisiana
You can just install an air horn; I could barely even hear the factory horn with the engine running
papakb
1,194
San Jose, Ca
True, the stock horns suck! I originally thought about air horns but then where does the compressor go? I ended up with a 24v Federal Signal siren from a Navy police car that has an electronic air horn that will also rebroadcast the radio thru the speaker.
mgFray
992
Southern Minnesota
The problem was the switch on the steering wheel. There is ground to the nut in the center, I connected the wire to that and horn went off.
Doing a voltage check between the "ground" side of the horn (with +24V connected), I got 22V. So that pretty much covers the resistance of the unit.
mgFray
992
Southern Minnesota
Ok, got a new button. Button now checks out electrically, but still doesn't work. After consulting the parts manual (for about the 5th time), TM-9-2320-280-24P-1 Figure 68. I just realized, the bushing (part 10) is missing. So even though the new button works, it isn't getting ground contact to actually work.
So _one more_ part to order.
20,468
Well that "bites" but at least you found the diagram in the TM.
Progress.
Slow but sure...
