- 2,308
- 893
- Fargo ND
Hey guys this is a question concerning my M920 setup as described in the title. The tires on my truck are all 98% on the no wear side and the truck is going to be driven on a long trip the tires are not to not exceed 55 mph, does that mean I am fine at 54 mph or should I be in the 50 mph range to be safe? Nest question is what would you run for tire pressure on this truck? Obviously because of the 55 mph limit they build a lot of heat so in my book that means to minimize the amount of sidewall flex as much as possible correct? I have the front axle tires set at 100 PSI but remember there is a lot of weight on the front axle and very little on the rears. Thoughts and suggestions please?
Karl
Karl
