I just swapped in a new trans my lmtv and it won't go into gear I have a code 4413, did I hook something up wrong in the transmission when I put new solenoid harness in I can't figure this out any help would be awsome
You’ll want to provide more info about your truck. Year, reason for trans change, what you were experiencing with issues before the change, what you’ve done since.
There are many members that have a ton of knowledge and will help but there are a few that are grumpy and will tell you to look at the TM’s and use the search area and google to find your answers…for the most part ignore them, but also do that when you can.
With that said, if you haven’t done so yet download the TM’s and go through them…however they are a PITA! (My opinion only)
Kinda new to MV ‘s myself so I’m not going to be able to help you on this one.
Good luck and welcome to the site!!!
Tom.
