M105A2 crank up landing leg question
BKubu
1,163
Gaithersburg, MD
(I reviewed the manual and was unable to determine the information I need.)
I have an M105A2 that was overhauled about 15 years ago by VSE. The landing leg on the trailer works, but it does not work correctly. As you are cranking it, you need to pull the handle back towards the trailer body to get it to properly engage the gear inside of the landing leg. If not, it engages, but it slips out of the bottom gear when under a load (as would happen anytime you want to crank up or down the trailer...even empty). I've had it apart a couple of times pondering how to fix the issue. It appears as though the gear attached to the shaft that the handle attaches to should have been mounted about 1/4" closer to the center of the landing leg. Does anyone know how this particular gear...the one that attaches to the shaft that the handle is attached to...is attached? There appears to be a roll pin, if I can see it correctly. I think the pin may need to be removed (punched through), the gear re-set, and then another hole drilled. This will be tricky. Does anyone have any input that might help? I thought of getting some type of collar (they make bolt-together spacers) to force the top gear to properly engage the lower gear.
Guyfang
23,989
Burgkunstadt, Germany
Yes, I seem to remember it being a roll pin. I would take it all apart, and see why its not working right. In the norm, and I only worked 4-5 times on said landing leg, but in the norm, The gear fits where its supposed to fit, and there is no re-drilling and mounting. I never saw a gear worn at all. The roll pin sheared off, happens often. If you look at the Repair Parts section of the TM, it tells you that the jack is SMR coded XA*****. That means its a pluck and chuck item. That's why there is no explosion picture and parts listing for the jack. Be careful, when removing the leg. Its heavy, and this type of landing leg has caused more injury, then I can think about. When I had guys removing or replacing the leg, I made sure the team had at least two if not three guys involved.
BKubu
1,163
Gaithersburg, MD
Thanks! The trailer is hooked up to a truck, so it is not going anywhere.
BKubu
1,163
Gaithersburg, MD
GUYFANG, as you know, there are four bolts that hold the leg onto the bracket that lowers it. I remove the top two, and loosen the lower two so that the leg can pivot within the mounting bracket. I loosen the lower two first...and then remove the top two. I am VERY careful when I remove the second top bolt. I hold the handle so that I can lower the leg carefully without smashing my calf or other appendages! :)
BKubu
1,163
Gaithersburg, MD
BKubu, If you're working alone maybe a strategicly placed piece of small rope would help prevent the landing gear from dropping with no guidance.
I also thought of a jack stand. But, as things would have it, my larger 7 ton military jack stands are not here. I appreciate your suggestion.
