jplace1011
- 488
- 63
- Santa Ana, CA
I feel like I’m just running around in circles here with my M1009!
When I picked up my vehicle, to fix an oil leak, the mechanic said he had to charge the two batteries overnight. All because it won’t start. I decided to test the batteries today and here’s what I got:
Off
Front 12.53
Rear 12.53
Off After a Short Drive & One Restart
Front 13
Rear 12.76
Running
Front 14.30
Rear 13.07
Running After a Short Drive & One Start
Front 14.40
Rear 12.80
The Rear Battery seems to be low. The Voltage Meter looks Low as well.
Note: The mechanic recharged the batteries and I had him Replace the Passengers Side Alternator. Alternator is from Hillbilly Wizard. The other alternator, Drivers side, was replaced just last year as well.
Today I also went around and made sure no cables or plugs were undone or loose on the Alternator and each battery. Both batteries were installed Dec. 2020. The Gen 1 & 2 Bulbs in the dash are turning on as well. I think the Alt belt is tight enough?
So what could be going on now?
Thank you for any help.
Off
Front 12.53
Rear 12.53
Front 13
Rear 12.76
Running
Front 14.30
Rear 13.07
Front 14.40
Rear 12.80
