Radiator Internals
TheControlVoice
Cypress, Texas
I hope this is not a stupid question but I was checking the coolant level and noticed the inside of the radiator. To me it looks like it has a lot of buildup. Adding a picture below. Just courius if this is an issue or not.
Keith_J
1,323
Schertz TX
Solder bloom, common problem with age. You could try cooling system flush but you can cause cooling system leaks.
If you can find a radiator repair shop, they might be able to clean and resolder the tubes plus seal any leaks for about $500.
chevymike
463
San Diego, CA
Yeah, that's about what mine looked like. Took it to a local radiator shop to have the boil and clean it but when they inspected it, they showed me how thin the tube are getting and cleaning it would result in lots of little pinholes. I had them re-core it and haven't looked back. Wasn't cheap but it was done right.
ssdvc
639
CT
This is the radiator I purchased for less than $279 shipped and a seller rating of 99.7 with close to 6000 sales: https://www.ebay.com/itm/2249683485...s=Year:1984|Model:K30|Make:Chevrolet#shpCntId
I am in the process of installing it now. She was well packaged, arrived within days, looks good and and all fittings look correct. Baring any unseen weld issues (doubtful) she looks like she will function great and last longer than the truck she is getting installed in. The one you reference from Amazon looks to be for an 87 up and may not be for your 84 spec truck.
ezgn
1,039
Lake Elsinore Ca.
That is a good deal on your radiator, I hope it turns out great for you and others that might be looking for a radiator to fit their vehicles. The CU850 radiators fit the cucv vehicles. It is the same one I have in my vehicle.
