- 3,532
- 3,433
- Brooklyn, NY
Dex III is the military recommendation IIRC
This is a "what have you done to your HMMWV thread, not a request for information thread, yes start your own thread! otherwize folks going down the "what has been done" thread have to sort through all this garbage.I'm going to be doing a fluid & filter change on the transmission and have some general questions not worth starting a whole thread for.
The 4L80E trans is the same as any other GM 4L80E trans? I ask because 2006 M1165 is not a vehicle for the purposes of searching rockauto, napa, etc. Does anyone know a vehicle I can use to search with?
I think I read I want Dex6?
Is the 4L80E trans pan the same as any other GM 4L80E pan? I ask because I want to find one with a drain plug.
Sleepy POTUS has ensured that it is $650to fill it.extended my range by 1000 milesView attachment 872257
Extending my Humvee’s range by roughly a thousand miles as well. Mine is a 78 gallon MRAP fuel tank encapsulated with “Battle Jacket” self healing coating. Will take multiple hits from AR-15 and other small arm rounds and continue to be serviceable . Watch video:extended my range by 1000 milesView attachment 872257
all in one day?Replaced all axleshafts, brakes, refurbished 12bolt wheel, with good tire for spare(still needs one bolt) and added cepek adjustable shocks.
