jplace1011
- 488
- 63
- Santa Ana, CA
Thank you for getting back to me fellas. I will still go ahead and fix the Fusible Link and check the end of the other wire. I might as well since it needs to be done anyhow.Sounds like a bad regulator if the main connections test out good. Solid red, Bat+, should be voltage of both batteries, red with white stripe should be front battery voltage. Measure with engine off, red to red, black to ground.
One idea I have is to put one of my Old Alternators in. I have one that was in when I purchased the vehicle. I just swamped it out because I figured why not. Let me see if that changes what comes up with the Voltmeter.
@Keith_J man I’m already lost in what/how to do that. I really need Videos on How To. It’s just better for me.
If the New one is broken, I’m going to suspect it could have been damaged during transport. Those UPS guys can really throw the boxes around. I know, I used to be one.
I already reached out to John at Hillbilly Wizard on Monday, so hopefully I can switch them out easy if need be.
I’ll report back.
