Deuce and a half questions about transmission
bilyeuc98!
Missouri
To start off I'm looking a A2 deuce and a half and the A3. I love the A3 with the single tires and I hate the double tires on the back of the A2 but I do like the multi fuel engine on the A2. Is it possible to put a multi fuel engine in the A3 and how much would it cost? Im thinking no because the multi fuel engine on the A2's we're manual and I was never taught how to drive one. I like automatics because I can get in it and go. Thanks for the info/knowledge.
montaillou
812
W.WA
an M35 is NOT the best vehicle for learning how to drive a standard.
I've been driving stick all my life and every one is a little different. You could probably find a friend with stick and ask them to teach you. 30 minutes to a couple hours and the rest of your life. It is one of those skills that might get rusty with misuse but comes back fast. If an M35 is all you got, as long as someone is there helping out I think it could be done.
ldmack3
1,739
N. Central Idaho
The A3s have that CAT engine.
Funny you should mention learning to drive a manual transmission using an M35. That's exactly the vehicle I learned on some decades ago.
Ah heck that's right. Forgot.
I was thinking 5 tons with the LDS.
I bet learning a stick in a deuce was an ... experience! I learned in a '66 El Camino.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I have seen and driven that A3 in Indiana, its a good truck! I'd be torn between the A2 and A3 only cause the A3 has no overdrive.
I love shifting gears!
I love multifuel!
The cat has more power!
Air assist steering is awesome!
Tough call, but if I were to choose between them, I'd go for the A3 in your case.
WOLF DOG
135
33
Eastern Shore MD
I have the A2 version with a manual transmission, and like the ability to decide which gear I want to use at a certain speed. By shifting gears manually, usually by sound and feel, I become one with the truck, which I enjoy. I also have manual transmissions in my F350 pickup and Jeep YJ.
rustystud
2,716
Woodinville, Washington
Now take that up one notch and learn to shift without using the clutch. It is a real good feeling to be able to shift by throttle and engine RPM alone.
I had to drive a platoon of my fellow Marines back to base after the clutch got stuck and would not release. That was three hours of fun !
