Hybrid MEP?
Light in the Dark
5,964
MA
The two wire lead on it was just twisted together before the reinforcement spring in the tube, so only in there an inch or two past what you see.
FarmingSmallKubota
1,117
Wapakoneta, Ohio
Heat trace maybe. curious was this one of the 802a's that have been coming out of Albany Georgia lately. All of those units seemed to have been highly modified with remote start and all kinds of stuff i have not seen before
Triple Jim
292
North Carolina
That should work fine for measuring coolant temperature, but just twisting the thermocouple wires together does not make a very reliable junction. Are you sure they're not twisted and then welded or soldered?
I've done things like this quite a few times when I wanted to be able to connect a hand held thermocouple thermometer for quick temperature checks.
kloppk
3,536
Pepperell, Massachusetts
The original thermocouple wires were probably much longer and the two wires were twisted and welded at the tip.
Looks like they chopped most of the wire off and just twisted the wires together and inserted them in the hose.
Here's a picture of one of my thermocouples showing the weld at the tip.
