Googledave
- 12
- 3
- Rhinebeck,NY
Hi all, first post here. I’m building an m101 cargo box for my m116a2 . Can someone provide me with the side height from the top of floor to top of top rail. Thank you! Dave
.Hi all, first post here. I’m building an m101 cargo box for my m116a2 . Can someone provide me with the side height from the top of floor to top of top rail. Thank you! Dave
Thank you very muchThis is an older TM, but you should find out measurements in it.
Well, honestly, I was looking for an m101a2 and a gentleman offered me his m116a2 with new tires for $200… and since I really need a box for mulch and have all the steel I need in my shop.. why not? I know it sounds like a lot of work but it’s really not that bad. That box design is perfect! Strong and super simple.Dave, I applaud your motivation, but why not just buy a bed. I have never fab'ed a bed...or anything for that matter...but I have to believe a lot of work goes into it. I know that some guys want your left b*** for a bed, but keep looking. Regardless, good luck with your project.
I just measured the top or top rail to top of fender and I’m at 12” on the nose. And that’s with 19.84” sides. Could the 116a2 fenders be different than the m101? Or is it just an optical illusion?So I have one more request and question. So the sides are 19.84”. But that doesn’t look right at the fender. Looks like distance, in pics, from top rail to top of fender is 6”…
Wow that’s is excellent! Thank you so much for the info!! I thought something looked different. That is the confirmation I needed!! Again many thanks!!M 101A2 bed - cargo
18" floor to top of bed rail
7 1/8" top of fender to top of bed rail
15 1/2" total fender height
23 3/4" horizontal part of fender (top)
14 3/4" front and back fender slants
-60 degrees downward angle from fender top (from horizontal) - front and rear
M116A2 bed - generator
8" floor to top of fender
11 1/2" total fender height
24" horizontal part of fender (top)
11 3/4" front and back fender slants
-55 degrees downward angle from fender top (from horizontal) - front and rear
M101A2 fenders are taller by 4". Fender angles are slightly different.
Hope this helps
Great information. Do you happen to have the fender dimension/PDF for a M105A2?M 101A2 bed - cargo
Hope this helps
Sorry, I don’t have a M105A2 in my green herd. The M101A2 and M116A2 dimensions are from trailers I can walk out and measure. The PDF is for fender extensions on the M101A2 tub due to the wider M116A3 axle/wheels (Hummer related).Great information. Do you happen to have the fender dimension/PDF for a M105A2?
