- 431
- 1,044
- 93
- Wapakoneta, Ohio
first things first. does the Generator start and run. You said you purchased a 12v battery for that. Well it would be 2 batteries since its going to be 24v. Military and i clearly see the NATO plug
Have you tried looking through Liberatedmanuals.com?ZeroBaseEnergy.com is down. Their Twitter and FB have not been updated since 2018. I'm wondering if they were another flash in the pan grift?
Is there a way to search for manuals on military equipment?
You will need to wake the inverter up enough to allow it to accept external power. I don't even think you will get the PV charge controller to add to the batteries until you have the inverter to where it turns on. This will depend on providing proper DC voltages to the inverter.I also would think you could charge the batteries from shore power regardless of anything else.
Thanks for this!You NSN has letters in it as well as numbers. My understanding is that is a format used when trying to enter a non-military item into the system. It is more like a local number that can be used to enter equipment in the Property Book. It is a work-around but it is not a full NSN so won't be in FEDLOG.
That said, their website was up in March so their old emails might still be monitored.
support@zerobaseenergy.com
info@zerobaseenergy.com
I meant to reply specifically.first things first. does the Generator start and run. You said you purchased a 12v battery for that. Well it would be 2 batteries since its going to be 24v. Military and i clearly see the NATO plug
