Unfortunately I haven't been on here in a few years or maybe it is fortunate because I haven't had any issues! Warning this could be a long winded post.
A couple of weeks ago I was getting belt squeal and noticed when it did happen my generator was over charging the battery. After trying the simplest thing first belt conditioner it continued to get worse. I assumed it was a bearing in the generator and luckily I had a 200 amp generator I bought when I first got the truck and the install kit so I wasn't too worried.
I get the 60 amp out and noticed the power steering pump also had a leak and ordered a replacement. Swapped the pulley over and it fit just like the original in there. When I went to install it I noticed it stuck out a belt length with the new 200 amp bracket. Kept going with the install because I wasn't 100% sure till I had the new generator in there and all lined up. I didn't install the jump cable on the generator.
Get the new generator in there and my observation was correct. Power steering pump is a belt length to far out. I finished the wiring and routed the now 3 belts as first belt excluding generator and the last two install around all pulleys.
Drove the truck to test the power steering and generator and everything ran as it should except I am only getting 24.7 amps from the generator and I don't think it is high enough to charge the batteries. Voltmeter is also border line red/yellow. When I tested the connector for the 200 amp jump cable it reads zero.
Any thoughts on first why my power steering pump is sticking out to far and do I have a bad generator? Any thoughts on troubleshooting? I am concerned one that I am running 3 belts instead of 4 and also that the generator isn't creating enough juice to charge the batteries.
