- 849
- 1,739
- 93
- N. Central Idaho
After hauling my 2nd load of topsoil at 3,600 lbs. I noticed white smoke coming from the slobber tube. I've checked for the signs of water in oil and see none. FDC bypass done. No whiteish foam on the valve cover oil cap, no increasing oil level, no decreasing water level. So suspect it is blow by. The smoke only appears as the engine warms up and it has been run pretty regular so not condensation.
I have been watching some slight leakage between head and block in 2 places and now three. Aft of #6, #1 exhaust manifold attach and now front right corner.
Starts easily, runs smooth and strong as far as I know.
So I am looking at pulling and rebuilding the heads for the leaks and to inspect the cylinders. It turns out I had a bad EGT indicator (replaced some weeks ago) but am unsure how hot my temps have been. Got a bad feeling on this. With the new indicator it did bump 1300F for a sec until I let off and downshifted on this last load.
All that being said if I pop the heads and see something I can't live with, depending on cost I would like to swap in an LDS465-1A or 2. (More power!)
Between a “good removed” LDT and a govt refurbished LDS it could run $2,000 to $6,500 + shipping. OUCH! I've also a tranny issue to correct. $$
With a good removed LDT I feel like I should at least pop the heads and inspect.
Coming off the road to my driveway is a sharp switchback so I don't think a wrecker could get around it should it break down on the road. I have to do a 3 pt turn with just the truck.
I'm looking for opinions, advice and suggestions from those with more experience in this area.
Thanks all!
Thanks all!
