- 494
- 1,070
- 93
I'm also hoping ditch the 330 feet of steel cable in favor of 500+ feet of synthetic. I've found some inexpensive ATV fairleads for synthetic line that might make great guides along the line path.
Fellas we aint in 5000 lb jeeps ! the lightest duece to 5 ton trucks from 20 tp 30 k of pull if your on flat dry ground then add you being in mud or a hillside you just doubled your pull so were back to 40 to 50 k of line pull the synthetic rope would have to be as big as your wrist and i always go back to how many wreckers/cranes use synthetic line ? OI'm also hoping ditch the 330 feet of steel cable in favor of 500+ feet of synthetic. I've found some inexpensive ATV fairleads for synthetic line that might make great guides along the line path.
Doubling the line does not double the pull on each segment of line. As long as the line is rated enough (plus some safety factor) for your winch pull there is no issue, no matter how many pulleys you compound. Getting 50k of pull is as easy for 3/8 synthetic as it is for the 1/2 inch steel. I suppose you could replace the 1/2 steel with 1/2 inch synthetic, but that is rated to over 30k of line pull, which is just wasted space on a winch that can only pull 20k.Fellas we aint in 5000 lb jeeps ! the lightest duece to 5 ton trucks from 20 tp 30 k of pull if your on flat dry ground then add you being in mud or a hillside you just doubled your pull so were back to 40 to 50 k of line pull the synthetic rope would have to be as big as your wrist and i always go back to how many wreckers/cranes use synthetic line ? O
Your right it is the shnizzle on 4x4s and the less than 10k line up and i fall in the tribe of seeing heavy equipment winched out of mudhole/ponds and generally bad spots with huge Caterpillar winches on the backends of D-8s and D-9s and seeing the myth like suction of mud on heavy stuff and them snaping cables of 3/4 in wire rope so ive never got wraped around the idea of less than steel for heavy equipment hense my 5 ton and trucks like it . And im wrong on a minute by minute basis around here lol its just the way i am like Merle Haggard said !Doubling the line does not double the pull on each segment of line. As long as the line is rated enough (plus some safety factor) for your winch pull there is no issue, no matter how many pulleys you compound. Getting 50k of pull is as easy for 3/8 synthetic as it is for the 1/2 inch steel. I suppose you could replace the 1/2 steel with 1/2 inch synthetic, but that is rated to over 30k of line pull, which is just wasted space on a winch that can only pull 20k.
I can't really speak to why wreckers and cranes don't use it more, but I suspect it's a bit of "we've always done it this way". I suppose they might be concerned about a couple of the downsides to synthetic, which are the fact that it does not tolerate high heat, and it's way less abrasion/cut resistant. There is also some concern with the way the outer layers can plunge into the inner layers on the drum under load.
But in pretty much every other way, synthetic is better:
It's lightweight (and even floats). Ever had to swim out with 50 feet of 1/2 inch steel cable to recover a submerged vehicle?
It's smaller in diameter, allowing me to fit somewhere between 500 and 600 feet of line on a drum that only held 330 in steel cable.
It does not have a memory. Ever suck a kink into your winch using steel line? That sucks.
It does not snap back (as much). Breaking a synthetic line is much less likely to injure or kill someone when it lets go.
Easily spliced in the field. (I recommend the factor 55 FID for this) In a pinch, I can cut off sections from the main line and splice eyes on it in order to create the rigging needed to get me out of a tough spot. Cutting and splicing steel cable is a big hassle, especially with bigger diameters.
NO little steel splinters. Dang, I hate this things jabbing straight through my leather gloves into the meat of my hand. and those always seem to be really sore and infected in a couple of days.
I know I sound like a cheerleader for synthetic, but I switched my 12k Jeep winch over to synthetic a few years back, and I'll never do steel cable again. I use that thing a ton. One of the reasons I wanted t get the winch going on my LMTV, is because I've used that little Jeep winch so much, often time outpacing the Jeep's ability to stay put and once pulling over my anchor tree in an attempt to remove a big bush with a double line pull.
For me the benefits of synthetic far, FAR outweigh those of steel. I just try not to run it by anything sharp or hot.
But as always, you do you my friend.
I wasn’t planning on using any You don’t typically use them with synthetics, you use a simple fairlead with a rounded edge. The only place I am looking at a roller is fairly close to the winch where I re-direct the line from perpendicular to the winch spool, to parallel with the frame. This one spot will always be loaded the same way so I may place a permanent shiv/roller with keeper guides there. The rear block will fit into a wider fairlead at the rear, and a simple smaller fairlead out the front… the original LMTV cable scheme used some fixed guide rollers along the fore/aft pathways mostly to clear the shock and cab lift cylinder, My first looks at it indicate as a foers setup, the need for guides will be less and those may be satisfied by simple round fairleads instead of the fixed rollers on the OEM winch, since they are at such shallow angles…Any comments on the steel frame rollers made for winched LMTV's?
There is no reason rollers cannot be used with synthetic. They just need to be smooth. Any nicks or damage from previous use with steel cable will quickly shred the new synthetic.Any comments on the steel frame rollers made for winched LMTV's?
.Hmm. Seems like mud and under road gunk might be an issue on the synthetic If left in place so is the intent to keep it wound up in the toolbox? I wonder if some sort of swab should be used as you thread through? Sort of a dummy rope.
When my synthetic gets gunk in it, I just unspool it and hit it with a pressure washer. Steel would just get rusty, and there's not much you can do about that, except grease the whole cable, and that's a whole new problem to deal with everything time you want to use it.Hmm. Seems like mud and under road gunk might be an issue on the synthetic If left in place so is the intent to keep it wound up in the toolbox? I wonder if some sort of swab should be used as you thread through? Sort of a dummy rope.
For the exact reason listed above. Steel is better around heat and sharp corners. And they have plenty of strong young soldiers to handle the heavy steel lines..
Hmmm....
The military has large deep pockets and a bunch of teens and twenty-somethings.
Steel Rope.
Synthetic Rope.
Wonder why the guys with more money than all of us put together picked steel?
