RJTM998
- 373
- 63
- North Carolina
Alright, guys had a couple of questions and needing some advice. MY M998 6.2 (Prestolite Box, Wellman glow plugs) was smoking on start up and was showing no glow plug activity on the volt gauge. I had the glow plugs switched out and all seemed normal and was operating as it should for a few days. Volt gauge showed plugs coming on during "wait" light startup and then cyclce a few times after startup and go to green showing charging system.
Then I was driving it today and I noticed my volt gauge jumping around and clicking from the start box. It was doing this while sitting at a stop light, not on startup. I got stopped and the clicking kept going. I unplugged the sensor and it stopped clicking at the start box. I am not sure I didn't kill my glow plugs again.
Start box? Sensor? Glow plugs? One suggestion I heard was try a new sensor first and see if that fixes it. (Because I have the Prestolite it is not a common easy to find the sensor.) My issue if that was not it I would be switching to the more common Nartron or KDS box which requires a different sensor.
I am tempted to just start over with a new Smart Start box, sensor and new glow plugs.
Can installing a new start box and sensor and not plugs hurt the new start box? Trying to not change plugs again if they are actually good.
I have read you need a certain alternator for certain start boxes?
Nartron? KDS? Which is the preferred box?
Also considering going with the new Camosystems manual glow plug box. Thoughts?
If you were in my position what would you do?
Thoughts? Thanks guys!!
