GASCANS001
- 48
- 18
- Fairmont West Virginia
I recently purchased a 1988 m35a2 deuce and once I got to the truck I needed to bleed the brakes. I flip the door up and found the mc. Now the weird part, it’s a plastic reservoir directly where the cast one should be. Added fluid began bleeding starting with the Mc and working from further to nearest. I flushed the entire system out of dot 3 back to dot5. I tried for 3 hours and never got any better (which I expected) sitting for some time. Next weird thing was fluid sound like it was bypassing inside the mc and definitely coming back into the reservoir. Is that normal? lines are in needing of some tlc. I plan to replace the entire brake system and rebuild my mc (if I can) and air pack (short style) In the near future. Trying to have brakes before hay season is over.
Where should I start?
concerns:
fluid bypassing
fluid returning to reservoir
no good pedal
plastic reservoir when normal cast
concerns:
fluid bypassing
no good pedal
