Wipers and etc are working . My Pcb box is brand new less than 2 months old. Supplemental grounding harness installed.
Could the voltage regulator play a role in no power?
No headlights, blinkers, brake lights, running lights.
excuse me ignorance but what does “TM” stand for in your post. Thanks
TM = Technical Manual. The one the dealer left out of the glove box.
Here's another free / guess / tip. IF for some reason the batteries were NOT disconnected when installing the connectors and the ENGINE connector just happen to go on OK first... PIN F is NOW HOT on the CABIN connector at ALL times. SO... GI JOE if trying to install the CABIN connector on and gets all sideways up under there with trying to locate keyway and fumbles-fiddles around and just happens to make contact with the CABIN F pin on the box to ground (very easy at this point) ... JOE just (likely) arc welded the F pin off the box or burned it back to a little nub. (check cable end too) Takes only a micro-second. Big flash and a OH OH Sh1T moment.
The "F" pin CABIN connector is also the "F" pin going to the lighting switch wire # 15A if I remember correctly.
Disconnect batteries and check around. There's NO fuses to look for. Box as stated provides no magic. Goes IN...Comes out. That's if it didn't toast inside.
Trying to figure or walk thru these type a problem is a crap shoot (already said that) so this is my free guess of the day. Eyes in the TM, eyes on the problem and a multi-meter and check check check. Good luck and report back.
Can't see it from here, Good luck, CAMO
I have some GOOD examples here at CAMOTEKSYSTEMS of this... POOF . Time to sleep.
