- 142
- 16
- 18
- knoxville tn
doing some front end maintenance on my M936A1 and noticed my front brake pads were worn more on the leading edge and trailing edge than in the middle. TM states pads are good till the bevel is gone. my bevel is near perfect in the middle of the pad but at least 30-40% gone on the ends. like they do not fit the hub well or shift while braking causing higher wear on the ends? my guess is, when the bevel is worn out in the middle the ends will just about be hitting the backing (all pad material gone). is this "normal"? truck has low miles (if accurate) and is running the pads that came from the army on it. both sides are worn the same. braking feels fine, and the truck stops well. thoughts???
