SmartDrug
- 303
- 63
- Saint Charles, IL
My M1123 has been giving me a few issues with the cooling system as of late and I'm having a hard time tracing the source.
Pertinents- M1123- 6.5 GEP 506 - New TDM (April 2022) and Thermostatic switch (August 2022) from Midwest Military Equipment, Cadillac valve tests at 78 Ohms, Power Steering fluid level checks out, fan engages and disengages when shorted.
The HMMWV has been running fine all season, rests consistently at 205 per the gauge, almost zero fluctuation there. About a week ago, I open the hood to check fluids and get ready for an oil change (500 miles on Odometer) and see that the washer fluid shelf has some red fluid on it, not enough to drip onto the floor, but enough to see it saturating the paint. I cannot say for certain, but I believe it was the return line to Power Steering from the Cadillac valve. I check fluid level in Power steering and sure enough, it's low, not empty, but low. It takes a few days for the Dexron III to show up, I add about 3 ounces and it's sitting pretty at the cold fill mark. No errant noises from Power steering or otherwise. I cut the Power steering return hose back about 1.5" and re-seat the hose clamp, no leaks or otherwise since.
Here's where it gets tricky, now the truck is reading an ever creeping temperature until it registered about 235 on the gauge and I shut it down. I begin to trouble shoot, test the Cadillac valve - it reads good at 78 OHMs. The fan is disengaged when started from cold and everything is plugged in, but turns on when electrical is unhooked, so I'm thinking the Cadillac valve is ok. When the Thermostatic switch is unhooked and that circuit is jumped, the fan kicks on, so I'm thinking the TDM is ok. This leads me to the Thermostatic switch, which I figured was faulty, and may have been causing the heating issue. I ordered a new one and received and installed it this morning. After a quick 10 mile run, it's doing the same thing, slow creep up in the temperature range until I kill the engine.
This is basically where I am with it at this point. I will add that the temperature at the Thermostatic switch reads about 180 degrees with an infrared thermometer gun, so there is clearly a discrepancy between the switch and the temperature sensor. My question then becomes, how should I proceed? I am hesitant to let the temp keep rising, for fear that the coolant temp just isn't registering with the infrared thermometer from the outside of the engine. I also can't run the truck like this, as the temperature gauge would basically be pegged all the time and no longer give indication, should something genuinely be amiss.
So throw it at me, what should be my next step in diagnosing whatever the heck is going on here.
