- 1,079
- 1,156
- Basehor, KS
When the A11 failed how many times and for how long did you push the S1 switch from run to start?
The generator will always produce a excitation when S1 is moved from run to start while running and you will see a voltage of 80 to 100 on panel voltage meter while S1 is in Start
And meter is set to L1 / L2
