jplace1011
- 488
- 63
- Santa Ana, CA
Final? Update:Truthfully you should not use post adapter on 3/8" threaded post batteries. You are asking for trouble anytime you drop size of battery cables and any connections. Plumbing rule is in effect. If you have a 3/8 Stud you get 3/8" current and amps. When the battery post is a solid post it has a solid connection and has not been reduced and expanded. Stick with solid post batteries on the CUCV unless you have altered to studded battery cable ends. Or NOT. But sticking with the tried and true always worked out better for me. Using the correct parts prevents what you have encountered. And if it were my CUCV I would have new cables made. They are inexpensive in comparison to all the work and damage bad cables and loose connections can cause. I had a battery explode under the hood of a CUCV about 10 years ago. It sounded like a shotgun blast and my picture perfect spotless engine was cover in battery acid and never looked the same again. Good Luck.
I put another Rebuilt Alternator (from Hillbilly Wizard) In and things are still looking good Voltage wise: from both Batteries and from both Alternators. That double confirms that the First Rebuilt Alternator was bad.
Process of elimination at work!!
Thanks again!
