- 1,025
- 1,475
- Wilson County, Texas
Everyone,
I thought I had it figured out, but I am second guessing myself and I am supposed to go pick the generator up tomorrow.
My goal is to use this for backup power at the two houses on my property. They are on separate panels of 240v but on the same meter.
I understand that the MEP-804B is ONLY 3 phase, but it can be run in 3 legs of 240v single phase is set correctly. That way, I can spread those loads out unlike some others that only have a single 240v lead going into their house. For example, using the attached chart from the TM below, using L1 and L0 (N) is single phase 240v.
Where I am a bit confused is I have read people are using these for home backup, but at reduced output due to not being able to utilize all the phases. But, maybe it's because I have been looking for hours on my phone, then a few more hours on the computer and my brain is fried, but, if using my L1 and L0 (N) example above, wouldn't this be a single wire with 240v when usually you have 2 wires of 120v making 240v to make power coming into a residential home panel.
Or am I just thinking to literally, and you would wire as you would with regular 240v single phase, say with L1 and L2, then L0 (N) is your neutral? All the legs in this setting are 120v, become 240v single phase when put together with a ground, and then 416v 3 phase when all 3 are hooked up to a 3 phase motor for example? And the TM is assuming you have the basic knowledge of this as it does when it comes to other things in TM's?
Here is a picture of the MEP-804B output lugs just for reference as well that I pulled from another members post.
