Algae in the fuel tank
Retiredwarhorses
4,182
Brentwood, Calif
This is what out of control Algae looks like, this is essentially tar, it’s in the tank, fuel lines, tank sock, pickup tubes, lift pump, filter, filter housing, fuel line, injection pump…solution was, everything listed was replaced.
The pump in this truck was essentially a brand new 6277, unfortunately it needed a new pump to run…a simple pulling of the fuel level transmitter is the easiest way to verify tank conditions.
The only way to clean anything is with brake cleaner…once done, and everything back to running condition, treat the fuel with a biocid.
Retiredwarhorses
4,182
Brentwood, Calif
Can you use some sort of bore snake/camera through the fill neck to check for this? And why doesn't the fuel filter protect the IP?
why not remove 5 screws and look into the tank? you get by far a better visual removing the sender, and your talking about algae in the fuel, it’s liquid, it’s in the fuel…like aglae in a pool, it has to be treat wherever the fuel was present.
Autonomy_Lost
1,537
Pennsylvania
I guess I'm assuming that you would have to drop the tank for that, but I haven't looked to see where the sender is. Sounds like its easier than I assumed.
Maxjeep1
1,916
Las Vegas Nevada
the Rear evaporator is made to be moved out of the way to access the fuel sender access plate….
The square box with the vents on it? I looked underneath for the lines and it didn’t look like it had very much slack in it. I need to replace that wood underneath it. I will have to get a better look at it. Thanks
Captaincarrier
241
St Pete, FL
View attachment 876434View attachment 876435
A very common issue with diesel fuel in a poly fuel tank.
The returned fuel can be near the operating temp of the engine and then when fuel level gets low the heated returned fuel heats the ullage area of the tank. Causes major condensation / water, which is the enemy of diesel fuel.
Poly tanks do not disipate the heat like aluminum or steel.
TNDRIVER
508
Cleveland,TN
Can't call it "algae" it displeases the new moderator.
