Ah and Evvy, post pictures of your Genset. Plenty off them, any and all detail.
We are suckers for pictures here…..
Peter
Hi Peter,
Pictures: I’ve been posting them as I go along in the various threads that I’ve started. I suppose I got lazy with this post.
How did I start the generator? I can start it if I persistently crank it albeit for just a few seconds at a time.
I didn’t remove the temp sender and clean it. It was a crude test where if someone told me that they got much different results and I could easily source it, then I would just replace it and be done with it. It’s not easily sourced that I can find so I’ll have to be more diligent in how I derive its characteristics. I’ll probably rig something to heat coolant on our campstove and then record ohms and correlated temperature rise.
With that said, it’s noteworthy that there are other problems with this set and they may be interrelated
1) Three blown gauges: fuel level, oil pressure and coolant temperature. They tested bad using the procedures in the TM, and… they are stuck in abnormal positions like always full, always no pressure, and always 180-degrees. That’s over all conditions.
3) Someone has attempted to rewire the components in the engine compartment. They did this by splicing 20-AWG mil-spec to the existing control wiring using inline splices. So far they have made correct connections, but I haven’t checked everything yet.
2) Low voltage. Noteworthy is that when I try to flash the generator the engine feels the load.
3) Fuel sender wasn’t bolted down. It’s shiney in my pictures in that thread, but that’s only because I cleaned it.
4) Produces constant blue smoke. Coolant level has stayed pretty much the same with just sox hours accumulated operation. I drained the water separator and didn’t observe any water.
5) The ring that goes into the pintle is bent suggesting that someone jackknifed the trailer backing up.
Following S.S. guidance, I’ve kept these issues in separate threads.
I love solving problems, always have, and I’m on track to having fun with this generator!
Evvy-
